N-Trouble wrote:
Bedlam wrote:
Is there any type of filter that can withstand those pressures that could be run inline with the pump and capture the failures? There should be a way to mitigate the pump coming apart if Bosch cannot remedy its current design.
Has been discussed on Dmax forum. Answer is basically no. Trying to filter a 29kPSI rail while not inhibiting flow is **** near impossible.
That's just it if the high pressure system cannot be designed to not have a catastrophic failure than the pressure needs to be reduced and the whole system re-configured. At some point it should be back to the drawing board vs. let's cross are fingers!
