Ron3rd
May 29, 2018Explorer III
jerem0621 wrote:
I ordered a Pro Series round bar weight distribution hitch with separate friction sway controls the last time I needed a WD hitch.
Most people on here will recommend a WD hitch with integrated sway control...that is well and good but it is not a necessity. You can order a 1,000 lb rated spring bar WD hitch from eTrailer with a sway control bar for under $300.00 and be in business.
Thanks!
Jeremiah
x2, get a WD hitch. The purpose of the hitch is to replace the load you took off the front axle by loading the rear axle. The WD hitch will restore the weight to your front axle.
You can even get a cheap WD hitch from Harbor Freight. They're all based on the original EZ-Lift hitch design.
Husky makes another inexpensive one. They all work the same, ie, spring bars that are suspended by chains off the frame of the trailer.
44,056 PostsLatest Activity: Jan 12, 2020
