ttavasc wrote:
To my knowledge this is not the payload off the OP's sticker but the max payload from the RAM web site. I saw where the OP confirmed the 6950 GVWR from the MFD BY sticker but indicated they didn't find the payload figure. If the OP has a Crew Cab instead of a Quad Cab this figure could be closer to 1050lb max payload.
Thanks for pointing this out.
The 1340# value does appear to come from a Ram Truck specs sheet rather than the "Tire and Loading Information" label.
I guess I was misled by the comment about the driver door sticker back at the beginning of page 3.
The OP should locate the yellow "Tire and Loading Information" label on the driver's side B-pillar.
He then can use the appropriate "should never exceed" value to estimate how his weights might compare with his truck's actual payload capacity.
Ron
