KillerIsMe
Feb 28, 2017Explorer
Brochure weights tell you how the empty trailer is balanced.
This is what I thought, which is why I was looking at trailers with a relatively low tongue weight. I don't want to overwhelm the truck. My thinking is that, because the water tank is on the tongue side of the trailers' axle I can add weight up front if necessary by adding fresh water. I was figuring on buying one of those Sherline scales and adjusting the tongue weight as needed. That's the trouble with not actually owning the trailer - you can't just take it somewhere and weigh it, so it's basically research and guesswork. And when you are cutting it close like I am it can make the hair stand up on your arms.
