Bionic_Man
Aug 01, 2017Explorer
anw7405 wrote:Bionic Man wrote:
The 6.2/6 speed tranny in my Yukon Denali offers significantly better performance than the 8.1/4speed in my old 03 2500 Burb.
If your new rig performs better than your old one, is say something was definitely wrong with what you had before.
Stability might be a different story, but that isn't what this thread was originally about.
Either way, I hope you are happy with what you now have.
That is suprising that you like the 6.2 better for towing than the 8.1. Comfort 6.2 all day long but the 8.1 is soo much better for towing. 6th gear in that denali was worthless unless you were on flat ground towing or not. It would not stay in 6th with the cruise on going up and down very very mild hills. I drove it through the rockies to trade it in for the 8.1 and it was searching for a gear the whole time.....no cruise and towing nothing but me. The 8.1 i set on cruise at 75mph and it kicked down a gear one time. By the way i did put a trans cooler on the denali and it helped the trans temp. However the engine still overheated some. Its just not a motor built to tow.....its for speed.
You are right, the Denali rarely stays in 6th when towing. Usually in 5th, sometimes in 4th, I think it goes all the way down to 2nd through the Rockies.
But I am not like some who cringe when a powertrain runs RPMs to keep in the power band. That is what they are designed to do.
And it really wasn't any different with the 8.1. Using speed control, driving 65-70 MPH in Eastern Colorado, the 8.1 wanted to stay in 3rd (which seemed like more RPMs than the Denali in 4th).
Up the Colorado passes, the 6.2 combo is a stronger engine - easily more speed going up than the 8.1. All while returning better MPG.
My 6.2 doesn't get much worse MPG towing my boat than the 8.1 did running solo.
As far as temps, I mentioned earlier that I think you are worrying too much about them. I really don't think the temps you were mentioning are outside of the operating range of the combo. I have seen 240* trans temp (pulling over Monarch Pass as well as Eisenhower), but they go back down when it isn't working as hard. And from speaking with GM techs, those temps, seen in spikes, are acceptable.
Not trying to argue (although it sure seems that way), but I am of the opinion that the 6.2/6 speed is a very good combo. Stability wise, your new rig will win hands down.
