Ripit
Nov 09, 2013Explorer
okan-star wrote:
Hey Ripit , I recall in another thread you said you had room in the basement for more batterys . Is that where your thinking of adding them ? Is your Outfitter a fiberglass tub or a wood -alum framed one?
The Outfitter I had was 2004 w/wood ,aluminum frame , there was an out side acsess panel on the pas side near the bat box , I moved my water pump with an accumulator into that area so it was quieter
I dont think there is any way that on my Outfitter the lower basement floor would hold up even one quarter the weight of one battery
Its top and bottom luon foam core light alum frame. I saw the whole construction of it when one of the holding tanks came loose and the bottom blew out and dropped down 2" while on jacks one day (Bob came to Ca and picked it up and fixed it)
Maybe suport from the upper walkon floor
If its a fiberglass tub , may not be a problem sorry I brought it up
There is a aluminum 4 Battery Box under the Dinette seat on the rear. Its cut into the basement so there is still storage under the dinette seat. I just switched out the two 12 volt Powervolt batteries and installed two T-105's. Going to see what difference this will make.
44,056 PostsLatest Activity: Nov 19, 2013
