Huntindog's avatar
Huntindog
I want a super bright Scare light!
I have what is probably one of the more common Scare lights.
It is 7" in diameter, and has these numbers on the lens: DOT I6S2T2 92. It came with a 1295, 35W bulb.
The lens has yellowed reducing the brightness, and the bulb just burnt out. Upon removing the lens, the material that it had for a gasket, some sort of white foam disintegrated.
SO since this thing needs some bucks just to get it back to stock. I figure now is a good time to upgrade. The local RV outlet showed me a replacement Fixture that has LEDs... I like the idea, but wasn't overly impressed with the number of LEDs that it had. I didn't count them, but would guess it as about 15 or so... And the package was touting the low amp draw... That is not really a concern as this light is normally used when the generator is running.
I am considering getting some more of the panel LEDS and wiring them into the old fixture I could likely get at least 4 of them in there.
I still have the issue of the gasket and the yellowed lens though, I need to upgrade those as well.
I am looking for ideas on what others have done, and what they liked/didn't like about it.
TIA
