Huntindog's avatar
Huntindog
I want a super bright Scare light!
I have what is probably one of the more common Scare lights.
It is 7" in diameter, and has these numbers on the lens: DOT I6S2T2 92. It came with a 1295, 35W bulb.
The lens has yellowed reducing the brightness, and the bulb just burnt out. Upon removing the lens, the material that it had for a gasket, some sort of white foam disintegrated.
SO since this thing needs some bucks just to get it back to stock. I figure now is a good time to upgrade. The local RV outlet showed me a replacement Fixture that has LEDs... I like the idea, but wasn't overly impressed with the number of LEDs that it had. I didn't count them, but would guess it as about 15 or so... And the package was touting the low amp draw... That is not really a concern as this light is normally used when the generator is running.
I am considering getting some more of the panel LEDS and wiring them into the old fixture I could likely get at least 4 of them in there.
I still have the issue of the gasket and the yellowed lens though, I need to upgrade those as well.
I am looking for ideas on what others have done, and what they liked/didn't like about it.
TIA
  • I am not the least bit concerned about what others think about MY lights. I am looking for suggestions on how to improve the present situation. Not criticism.
  • 2oldman wrote:
    I prefer the dark at night. Seems like outside lighting just attracts bugs.
    I agree. I enjoy the dark.
    The OP didn't say who or what he wants to scare with the super bright light. Maybe he is having a problem with people or creatures?
  • The number of LED's makes no difference in its output since you have no idea what the output of each is.. You need to look at it , but also remember that everything makes heat, including LED's. While a brighter incandescent will burn out the fixture, LED's will just kill themselves. So choose wisely.
  • Neighbors should be happy wearing sun glasses at night....lol.
  • I don't have a bright exterior light. The lamp is a single 36-3528 LED panel. It works fine for me now and I have plans to put some floods around, later this year.
    Your fixture sounds like it's seen it's days unless you can find a replacement lens. The gasket could be replaced by weatherstripping.
    If you're thinking of upgrading to LEDS, I would just get a new fixture. Some of the newer LED's can be very bright so count doesn't play that big a part, anymore.
