Cummins12V98
May 21, 2018Explorer III
FishOnOne wrote:Cummins12V98 wrote:
"Reduce air pressure improves ride a bit but increases wear rate"
FISH this time you are way out in left field with that comment!!! Using weight/inflation chart to set PROPER air pressure will NOT increase tire wear!
On my 2500 4x4 RAM I could easily get 100K out of BFG's and 120K from Michelin's by reducing air pressures based on load.
Anyone who pulls some weight would be hard pressed to get 100k-120k miles on a set of tires.
Probably a figment of your imagination.
Never said I was pulling a lot of weight. It was while I was commuting while in Construction.
But your comment was simply wrong. Don't try to deflect!
