davisenvy
Jun 16, 2020Explorer
MFL wrote:
This trailer being a toy hauler, has a heavier than normal dry hitch wt, to offset the toy wt added to rear. While the OP will be pushing his trucks limit for payload, if he loads wisely in the trailer, and truck, it should be an acceptable towing experience. Much of toy wt will be behind trailer axles, and this is not a real long trailer. I'd give it a go, if my truck/trailer. As always, a good WDH will make some difference too.
Jerry
This is my thinking also. I shouldn't have to have to explain how many people, how far I'm towing, what exactly I'm taking with me. I understand how payload works. Anyways here I go, Dr650 dual sport motorcycle 320 lbs, some fire wood, necessities in the camper 300 lbs(Yes 300 lbs because I have weighed it), 1 person 220 lbs, and my lucky rubber ducky. Not going to tell you where I'm going and not telling my favorite fishing spot either. I will say most trips are within 30 mi of home. If I load this weight behind the rear axle, wouldn't that be to my advantage?
44,065 PostsLatest Activity: Apr 14, 2026
