Siletzspey's avatar
Siletzspey
Ideal V8 rpms when towing?
My F350 SRW 4x4 with 6.2L gas has a 3.73 axle and 18" tires. I carry a 9'6" NL truck camper which puts me at about 11,000lbs total.
When cruising at 70mph, I turn 1,800rpms in 6th gear, and 2,300rpms in 5th gear. On a mild up slope the engine seems fine in 6th at 1,800rpms (e.g. I don't get any odd sound or sensation of lugging).
Is there any thought on what a good rpm is for the engine and transmission when towing a load? With my prior 1997 Ford Expedition, the TOW button would disable the highest gear (OD).
I also plan to upgrade to a slightly larger 18" tire so I can go from 3,640 to 4,080lbs per tire, and estimate 6th gear will drop to 1,700rpms, and 5th to 2,200rpms. I wonder if I will want to purposely avoid 6th?
Thanks,
--SiletzSpey
