machunt
Apr 30, 2013Explorer
towing rpm
I have a 2004 dodge CTD with 3.73 rear end when i tow my 5ver in tow haul mode my rpm,s are runnibf 2500 rpm at 60 62 mph, sound about right? truck is a 4speed auto
john&bet wrote:
I tried it yesterday afternoon and it does not shift into 4th. The torque convertor locks up and it stays in 3erd. If I hit the button at speed it shift down to 3erd and torque convertor unlocks, then a few seconds later the torque convertor locks up again. Just how mine works. Others may be different. I have a Jan.'04 build date, with 325hp,600tq.
45Ricochet wrote:2500 Grunt wrote:
The 2005 year Cummins is the only year where the tow/haul button once pressed only alters the shift points in gears 1 thru 4 or raises the rpm shift points. It will not lock out 4th gear (overdrive) unless you purchase an aftermarket OD lock out switch/box. Don't know why Dodge engineers did this but they switched back to the other way in 06? To the OP, sounds like you are running in 3rd gear at 2500 rpm's unless you are running 4.56 gearing in 4th? With stock tires with 4.56 gearing in 4th gear you should be around 2300 rpm's at 65mph +/_ (can't find the gearing chart).
Just to clarify, 06 here and the button is a three way switch. Yes push it once for tow/haul which changes shift points, twice it will lock out over drive, third push will be normal operating condition. I believe 2004.5 back they were only a two way switch which would lock out over drive.
john&bet wrote:I tried it yesterday afternoon and it does not shift into 4th. The torque convertor locks up and it stays in 3erd. If I hit the button at speed it shift down to 3erd and torque convertor unlocks, then a few seconds later the torque convertor locks up again. Just how mine works. Others may be different. I have a Jan.'04 build date, with 325hp,600tq.boogie_4wheel wrote:I don't notice mine shifting back to 4th under load. I will try what you suggested after bit when I have to go to town just to see.john&bet wrote:boogie_4wheel wrote:With reguard to the t/h mode, if I push the button I run the ops' rpm. I put my '04.5 in D and go. I very seldom push the button. I generally run 1800 rpm on the interstate with very little down shifting and 55 mph on other roads.
If this is an early 04, try running with the T/H off. This will allow it to drop into 4th and would probably net you some fuel economy. Save T/H (OD lockout) for the hills.
The 04.5+ T/H allowed 4th gear operation, but 04 and older was an OD lockout feature. I don't know the specs on your FW but would at least try to pull it in OD.
Maybe I'm wrong... The T/H on the '04.5 is still only a lockout :? When you first enable T/H while under way, the truck will downshift to 3rd, but after a few seconds it will upshift back to 4th. Try it from a stop empty with T/H enabled, truck should go into 4th at ~45mph with light throttle. If it doesn't then I was wrong and the T/H with 4th enabled is an '05+ thing (not an '04.5+ thing).
For the OP, I would still try running without T/H enabled and pulling in 4th.
Hannibal wrote:Mote wrote:
My old Dodge with the Cummins won't even turn 2400 rpm. The govenor limits it to 2200rpm which is around 55mph with overdrive locked out. At that rpm it sure is loud.
I can run overdrive when pulling the camper most of the time when on the highway. I do have to be carefull pulling hills thou as the torque of the engine is to much for the trans to handle and it will slip.
Something is wrong there. Peak HP is at 2600rpm. My '95 and 98 12v would both run to just above 2600rpm before the governor would reel it in. Even then it felt very ornery compared to the ISB and ISBe. They started to run out of breath just over 2900rpm but I believe if I remember right they were governed at 3200rpm.
