bigfootford
May 05, 2016Nomad III
My ladder has 8 bolts holding it to the side of the camper....
The ladder tubing is bent at the top and curves 180 deg and mounts on the top of the camper.
Any downward pressure, climbing on the ladder or static weight is distributed through those bolts and the tubing of the ladder. I have no doubt that there is enough strength to accomplish carrying the 3000.
Mind is a bit different that Wayne's. The drivers corner of the rack frame is anchored to the jack bracket. So at least 1/4 of the weight is supported there in that corner. Anchoring the rack there also creates a firm hold on the rack so there is absolutely no left right movement nor any up down movement in that corner, that could be detrimental to the ladder bolts..
Wayne's Rack is what he calls REV 3.... He added the angled tubing that you can see to have the outside/rear, passenger side of the rack secured there and to the jack bracket so there is no up down flexing of the rack to the ladder bolts as mine was done.
This is not a low skill fabrication project.
Wayne is a great fabricator and welder...
Jim
Jim
44,056 PostsLatest Activity: Jan 19, 2026
