rmoparman
Nov 16, 2013Explorer
Ike Gauntlet
Anyone seen the Dodge pulling 17,500 trailer up the Gauntlet. Man if it struggles with this weight no way it can pull 30K. Im a Dodge guy but i think none of the big 3 could tow up this grade.:)
jus2shy wrote:wilber1 wrote:skyhammer wrote:mpierce wrote:skyhammer wrote:
The Dodge sounds loud and I am surprised that it doesn't have a gear indicator.
Yes, it does. Just push button to shift once, and the gears appear. Which gear you are in, and which gear you have limited it to.
I was wondering, as the driver of the Dodge was guessing at what gear he was in.
Perhaps a 2014 owner can enlighten us. The ERS indicator on my 2011 only shows the top gear the transmission can use. It doesn't necessarily indicate which gear it is using.
I own a 2013 and that's been my observation as well. The ERS will only indicate the maximum gear the truck will shift up to. There is no actual gear indicator that I'm aware of on my truck.
