carringb
Nov 05, 2013Explorer
The regular scangauge II will allow you to read the data stream on your 6.0. You do not want the Diesel version because that has an medium-duty truck connector and not OBDII.
The problem is its digital nature. It's hard to see trends without an analog gauge (or a visualization of one). Also, at some point you will need to test cylinder balance, which you cannot do with a scangauge. Also, you can't monitor enough channels at once to accurately diagnose no-start or even rough-running conditions. That's why I recommended auto-ingenuity. Ford IDS is even better because then you can do your own firmware updates and flashes but it is more $ overall.
I also highly recommend a good shop manual. I found AllData to be extremely useful for doing major 6.0 repairs. They have a non-commercial version which isn't too bad cost-wise:
http://alldatadiy.com/ It comes with all the diagnostic flow-charts you would get in a Ford service manual, along with wiring and other system diagrams.
