OhhWell
Nov 14, 2013Explorer
vacuumbed wrote:
I cleared the codes, they are all gone including the P1260. None of them will come back even after a few key off, then key on, then start cycles.
It's now a no start with no codes to go on.
Like the post a few up had said, the security module needs to be reset. Nothing is 100% certain but if it ran for a couple seconds with starter spray or whatever it was you sprayed in the intake and you had the theft code with the light on the dash, then it all points to the computer stopping fuel delivery to "Immobilize" the engine. It is likely a dealer problem but there are some locksmith shops out there that have systems to access the security module.
I wouldn't assume that just because you cleared the code out of the OBD system that the theft state is cleared. That would seem to make it a little too easy for a thief.
