Nvr2loud wrote:
Buy it!
Just kidding, if you're happy with your current unit then don't spend money on this one.
The roof is better then your current roof? What is wrong with your current roof?
My currant roof is getting cracked at the edges. I found the cracks last year and sealed the edges with some Dicore sealant. (Good stuff by the way) on the one corner of the roof there is a little bubbling and if you push on it you can feel that the plywood underneath is just a bit separated. This section is about 5 inches square and there is no water damage inside. Because I'm only a weekend camper and I have the leak fixed now I'm not worried. I know, many of you would freak and feel the need to fix the whole thing but, the way I use my TT and because it's stored inside most of the time I'm not worried. But, the whole roof is kinda discolored and it should be coated with some of that stuff that you roll on with a paint roller. However , once again because it sets inside 321 days a year I believe I'm good to go for a couple of more years.
