Grit_dog
Jun 17, 2017Trailblazer
Troutguy wrote:
My AF 811's bathroom and fridge is accessible with the slide in, although you may have to suck it in a little to get through (I should probably suck it in all the time anyway). The main concern about partially opening the slide when using the lavy/fridge is remembering to close it fully when getting back on the road again......and the additional wear and tear on the slide motor and mechanism.
When I bought this camper I was hesitant because I didn't want a slide but now I could not own a TC without one. I've been lusting for an AF992, although I personally haven't seen one, however it looks like you have to almost open the slide fully to access the fridge and lavy.
Same here, can squeeze by unless I put on another 20 lbs, lol.
Fwiw, we usually run the slide out a little bit when gettin in for lunch or something. I can report that leaving the slide out a bit and driving. Down the road has so far had no negative effects. More than once I'll notice, an hour or 2 after getting on the road, that the slide isn't all the way in. So no harm no foul if you forget, at least on my old AF campers.
44,071 PostsLatest Activity: Aug 30, 2026
