FrankShore's avatar
FrankShore
Important Travel Trailer Question
My TT has been in storage since last May. I took posses13ion in Jun3 2013 so I need new tire. I took possession in May 2014, and I need
2 are very low pressure, what would tyou do ??
Is there such thing as a mobile RV TV TIRE service? I'm in the Pasedena, area
Thanks!!
  • If you don't trust the tires then grab your jack & jack stands, take off the tires/wheels, haul them to your local tire store & replace.
  • are the tires damaged? whats the date code on them?
  • Unless your just going to park it someplace else, you need a small air compressor so you can check tire pressure before every trip. So you may as well get one to air them up this time.
    Not sure why you need a new tire though?
  • I'm sure you could find a mobile tech that would change/service your tires. It may not need to be an RV person, but a tire service center may have a mobile tech too. Call around...tire shops, or large campground, to inquire about an RV tech.
    Good luck,
    Jerry
    Thanks!!
    Sure there is. Look up just about any tire shop and give'm a call.
    Ron
  • Air up the tires and tow it to a tire shop ?
    Get yourself a road service and call them for 2 flats ?
    Your post makes no sense.
    Glad I'm not the only one that may no sense of that
