NC Hauler wrote:
rhagfo wrote:
schlep1967 wrote:
Is 15K the max weight on the trailer or the empty weight?
My 5th wheel weighs in at 10,560 dry with a max of 14,000+. I have firestone airbags added to my Dodge 2500 and run about 22 lbs in them. If you are starting at 15K you need more truck.
X2
Pretty much the nail on the head! HD2500 is a 3500 with a tax break. That being the 10,000# GVWR limit. The differences between 2500/250's and SRW 3500/350's is the Class 2 GVWR of 10,000# and possibly softer springs.
It is the owners choice to exceed the GVWR, no suggestion to do so.
Yes, will be over GVWR, the numbers to watch then are the TIRE max capacity rating.
2008 Chevy/GM 2500 has a GVWR of 9200#, not 10,000...As stated, the spring pack on the 3500 SRW truck is different than one on 2500.
He has exceeded his GCWR by 500#,
If 5er is at 15K, odds are, his pin weight is closer to 2800-3000#.
I prefer not to go over RAWR...putting TIRES on that will cover payload, BUT NOT the axle weight rating, doesn't make since and just made the axle the "weak link"...
OP stated he had weights, but was "guessing" on the pin weight...That weigh is very important to the whole scheme of towing a 5er...and dry or empty weights are a joke...no one goes camping with an empty or dry weight camper.
I agree unless used as I did. Starting with a trailer with a dry weight of 10,560 you are going to end up a whole lot lighter than starting with one with a dry weight of 15,000. And that difference in this case would without a doubt require more truck than a 2500 series.- NC_HaulerExplorer
X2
OP stated he had weights, but was "guessing" on the pin weight...That weigh is very important to the whole scheme of towing a 5er...and dry or empty weights are a joke...no one goes camping with an empty or dry weight camper. - mkirschNomad IIThe brochure didn't say it was going to be COMFORTABLE. All it said it that the truck could tow that much.
- ktmrfsExplorer III
X2
3500 has a bigger spring pack, and stiffer overloads, along with tires with a higher weight capacity.
I agree, 2500 is overloaded by the mfg ratings. I have a 2500cc short box and cargo capacity is around 2400lbs. 3500SRW all 1500 to that number, along with much stiffer spring pack on the rear - CWSWineExplorer
Gnsolman wrote:
Thanks Jimln My Durmax is rated for 22000 lbs Thats for a combined weight of the truck and the trailer Last I put it on the scale it came in @ 22500lbs and I had fluids in the tanks We also emptied some items So long story short we are well within the GVW of the vehicle Weights I believe the fifth wheel pin weight for the trailer is at about 1750lbs What started my whole search was we just moved are fifth wheel on a 1100 mile trip We came home without it We felt great when we got out of the vehicle running without the fifth wheel. With the fifth wheel stiff and sore for the first few steps getting out for fuel We have traveled from Florida Keys to Alaska so lets just say I've hauled the fifth wheel over 50000 mile on various trips
I'm liking the airbag suggestion Thanks again Jimln
15,000lbs times 11.5% = 1725 lbs pin weight. 11.5% is really low for 5er pin weight. Normally they will north of 20% or 3,000 lbs. Recommended is between 15% and 25% with most of them at that weight are north 20%. - Grit_dogTrailblazerWell, welcome!
The weight cops jumped on this one early......
As said, your 2500 is really a 3500 with a tax deduction and softer springs.
Not sure how stiff and sore equate to pulling the river vs driving empty.....anyway.
You've pulled a fiver for 50k mi. Presuming this fiver and truck??
If so, you've either been driving with the rear end of your truck squatted out for that long or you really have a light pin weight as stated.
You don't even specify what you're looking for, rather complaining about the drive......
So to put together a bunch of assumptions, I'll assume a light pin that the 2500 factory springs are handling alright, but you're getting sick of the big 5ver bucking the truck all day long. Am I on track so far?
Provided you're not overloading the heck out of your rear suspension, stiffer leaf springs or airbags and good shocks or an air ride hitch will all serve to reduce the bucking in their own way.
Otoh, if it's just your nerves shot from white knuckling a big arse trailer X country, then a bigger truck or less towing may be the solution.
If you sensed any sarcasm, it's because you need to describe your problem and what you're trying to accomplish....... - rhagfoExplorer III
Michelle.S wrote:
WOW, 15K 5er and pin weight of only 1750, you must have a ton of weight hanging off the back to lighten up the pin that much since the typical pin for 15K should be in the 3K area.
By your own words (We felt great when we got out of the vehicle running without the fifth wheel) vs (With the fifth wheel stiff and sore). Seems to me that's it's not such an enjoyable experience.
Need I say more, since you said it yourself?
Wow, for sure not a great ride, with that low of pin, at 11,000#+, we run at 2,100# to 2,200#.
That is only 11.6% pin WAY too low for a 5er. - Michelle_SExplorer IIIWOW, 15K 5er and pin weight of only 1750, you must have a ton of weight hanging off the back to lighten up the pin that much since the typical pin for 15K should be in the 3K area.
Need I say more, since you said it yourself? - GnsolmanExplorerThanks Jimln My Durmax is rated for 22000 lbs Thats for a combined weight of the truck and the trailer Last I put it on the scale it came in @ 22500lbs and I had fluids in the tanks We also emptied some items So long story short we are well within the GVW of the vehicle Weights I believe the fifth wheel pin weight for the trailer is at about 1750lbs What started my whole search was we just moved are fifth wheel on a 1100 mile trip We came home without it We felt great when we got out of the vehicle running without the fifth wheel. With the fifth wheel stiff and sore for the first few steps getting out for fuel We have traveled from Florida Keys to Alaska so lets just say I've hauled the fifth wheel over 50000 mile on various trips
I'm liking the airbag suggestion Thanks again Jimln - Cummins12V98Explorer III
Strabo wrote:
Cummins12V98 wrote:
Bags and 19.5's you can tow anything!!!
Thats how we roll in the toyhauler section!!!!
Honestly I wish more people would. It is very sickening to see all these 250/2500 trucks heading to and from the desert on I-10 in the Palm Springs area with their AZZ dragging and head lights pointing to the sky. Oh yea bouncing along with the big fatty tires.
44,070 PostsLatest Activity: Jul 01, 2022
