YA....OK!!! Let me just forget about the 8500 it will rake to fix it. I've taken this TT back to them 4 times to fix stuff and it wasn't stuff I found either. It was them calling me to return it so that they could fix the door again and replace the gray water tank because supposedly they ran their water from the service department into it and found out it was contaminated. So they had to have known that there was damage. At with one of those times their servic department had to have known that the damage was there. I am not going to just forget about the AS IS🤣😂.According to the research ive done and talking to different RV companies. Their supposedly to disclose that information even if it is an AS IS contract. The travel trailers in California run under the same guidelines as buying a mobile home as to where if something, like the waterheater doesn't work and they don't tell you and it blows up and floods your house then their liable. Especially if its not disclosed in the contract but yet they didn't even disclose it at the time of purchase but knew about it, then their liable for such damage.
You should re read this and pretend you didn’t type it. You’ll see the issue. You’re being a fool and being taken advantage of.
You are either posting some embellishment as click bait or getting suckered in big time. Stop that.
Yiuve turned a sticky door latch and some hump in the floor that you’ve forgotten to actually describe or explain into this huge worry and mess.
At this point you’re almost as much to blame as the dealer ripping you offf or trying to rip you off. Stop that and use some common sense even if knowledge is lacking.
