- apr67ExplorerI thought off level operation of absorption fridges wasn't an issue if it was on 120v?
- lovemyttExplorerI enjoyed it as well.
- readytowExplorerHaHaHA! Old-Biscuit said hogwash!!!
- Old-BiscuitExplorer III
chevyman2 wrote:
NOW LISTEN CLOSE... After you move the TT back to more level ground. I would not turn the fridge on for at least 24 hours.
Hog wash........
absorption fridges have no moving parts..they work off thermodynamics and gravity.
Operating 'off level' will cause accumulative damage
Storing it off level has no effect on a non-operating fridge.
When you get rig level the ammonia solution will equalize in absorber tank and liquid heat exchanger.
Turn it ON.
It might take 24 hrs. to fully cool down but you don't need to wait 24 hrs. after leveling to turn it on.
Don't even have to wait an hour. - bob213ExplorerWhere my nephew lives the driveways are at an extreme angle. Many of the people who park their trailer or boat in the driveway have put posts in cement with a chain welded to it. They then wrap the chain around the axle for an added bit of protection in case a chock gets moved or breaks away. Alittle more peace of mind if nothing else.
- limberyExplorer
phillyg wrote:
Left to right, no. Fore and aft, yes. I level the trailer to the slope to ensure the weight is equal on each axle, too.
How do you do that on a slope? Mine is jacked up in the front as high as I'm comfortable and it's not completely level F to B but there's obviously more weight on the rear axel than the front... - phillygExplorer IILeft to right, no. Fore and aft, yes. I level the trailer to the slope to ensure the weight is equal on each axle, too.
- lovemyttExplorerThank you so much. I hadn't considered the refrigerator. I will see what we can do about leveling once it's parked. Building a platform for the jack may work out to be the best solution. We have x-chocks on order. Plus we remove the battery every time we store. Those things are valuable!
Additional weight to the rear may be an issue. I wont give up my storage space until i think we have the right solution. I dont want to cost more in repairs than rent. All for the cost of convenience.
Thanks again. - IndiandyExplorer"NOW LISTEN CLOSE... After you move the TT back to more level ground. I would not turn the fridge on for at least 24 hours."
24 hours????? - danorenExplorerI agree to the posts above and just want to add that it will help water/snow to slide off the roof easily.
When I store the trailer I create an angle for this exact purpose.
44,052 PostsLatest Activity: Nov 23, 2025
