abmatos714's avatar
abmatos714
Incline Parking Tips
Hi. Looking for some tips for parking on an incline. We close on our new house in Jan and the driveway has some incline to it. We’re still fairly new TT owners so I’m not super familiar with anything like this. I’m not sure the exact slope but I was going to attach some pics for reference. I’ve read a lot about building up wood blocks for under the tongue jack and trying to take some pressure off/level the axles.
We have a 25ft FR Salem Cruise Lite. No slides. It would be parked at the house year round (minus the camping trips) and ideally stay plugged in for the fridge only during the season. We have X chocks and I was going to pick up some heavy duty rubber ones in place of our cheap plastic chocks as well. We would be in and out of the camper for loading and unloading between trips.
Does anyone have products they use or simple build plans for whatever they use to level everything out?
Any tips or help would be appreciated and pictures are great!
Thank you!
  • Gdetrailer wrote:
    X chocks like these that goes between the wheels?
    On a slope?
    I would not bet my life on those things to hold any trailer on anything more than a very gradual slope..
    Yeah, I know, there are folks totally devoted to these things and will risk life and limb and defend them til their deathbead..
    They are not real wheel chocks and anyone who says they are , perhaps they can point out how many truckers use them? Those things will never pass the sniff test of any OSHA safety person as wheel chocks.
    They depend on your tires staying in place, not moving, not shrinking.. In reality, tires move around when you walk in the trailer which can dislodge x Chocks, tires shrink as the lose air pressure.. So, you have to keep snugging them checking them to make sure they have not shifted and you must keep putting air into the tires to keep them in place..
    They have a habit of popping out if you don't bother checking them once and a while or if you set them when tires and air temps or hot and didn't bother to recheck them later.
    Tires naturally lose pressure, 1 lb-2 lbs per month, tire pressure goes up and down with air and tire temps..
    They are designed to reduce wheel rocking while camping that gives you a forward/backward motion in the trailer, you should ALWAYS use REAL wheel chocks in conjunction with X chocks..
    Even the cheap yellow chocks are far more reliable on sloping ground..
    About $9 per pair..
    For concrete/asphalt surface, get the heavy duty rubber versions which are more like the ones required by OSHA for truckers to use..
    Pricey? Yep at $35/pair, but how much is your life worth? How about Your families life? Neighbors life?
    My post stated I had X chocks AND that I was already going to be picking up/using the heavy duty rubber ones. We currently have the yellow plastic chocks and use xchocks to reduce rocking when camping. The xchocks would not have been used as the main anti-roll device. I was simply stating we already had them as I had seen them suggested elsewhere.
  • IDman wrote:
    How are you going to get a car into the garage with a TT in the way? Have you checked with your HOA to see if it is okay?
    I would also asked my neighbors if they object to the TT parked there as it looks like it will dominate the front and block the view of cars coming around the curve.
    We don’t use the garage for parking. No HOA. Street parking is allowed and aplenty. We actually can park the trailer on the street from April-December and many other houses in the area have trailers either in their driveways or out front.
  • X chocks like these that goes between the wheels?
    On a slope?
    About $9 per pair..
  • How are you going to get a car into the garage with a TT in the way? Have you checked with your HOA to see if it is okay?
