patperry2766's avatar
patperry2766
Explorer II
Jun 30, 2014
increase shower water pressure
I had to replace the shower hose and I noticed that the connection for the water faucet only had a small hole to let water pass. The faucet has never had great pressure, so I was wondering if I could drill out a larger hole, if that would allow more water to pass, thus increasing the pressure?
  • If your shower head is mounted on a flex hose you will find that hose also has a very small diameter.
  • If you can get more volume upstream of the shower head you will get more pressure at the shower head. If you increase volume by removing flow restrictors at the shower head you may not get a pressure increase. Are you using a pressure regulator? What pressure is it set at if you are?
  • I replaced the shower head in the bathroom with a Oxygenics but I haven't had a chance to use it yet. Doesn't more volume beget more pressure to a certain extent?
  • A larger hole will increase volume not pressure . Is more water what you want or higher pressure ?
  • The small disk is a flow restrictor. Designed so you use less water. I would take it out! Don't bother trying to drill larger hole.
  • I think that disk with the small hole in it comes out without a detrimental affect on performance. Also check the shower head itself for small holes.
    The alternative is to go with an Oxygenics shower head. Search this Forum for more info on Oxygenics.
