wmoses
Nov 17, 2013Explorer
Bathroom access is more important than fridge access if only one could be had. In my RV, Bathroom access is fine since it is in the forward midship area so no slides are involved. But to get into the fridge once of my rear slides has to be moved a bit to allow you to get by. The slide the fridge is in does not have to move.
This is not a problem for us since we load up prior to the start and if on a long road trip where replenishments are needed we get them when the RV is set up. On the other hand the bathroom always can be used at every gas stop - a major advantage since there is no need to use the gas station facilities.
44,054 PostsLatest Activity: Dec 18, 2025
