Harleybullet's avatar
Harleybullet
Info on Casita trailers or Lance 1475
Moving from a truck camper to a small TT. Still have the truck and we boondock in Az, every winter from NY. Any info good or bad would be nice... thanks
  • I don't own either model but have been in a 1475. I think everyone is assuming 1475 not 1475s so you might want to clarify that as the s is completely different.
    For me the biggest consideration would be the much shorter and narrower dimensions and better aerodynamics of the Casita (which I'd like) vs. the extra 4 inches of interior height in the Lance (which I'd also like.)
  • Tibbitts
    I really did not know that there were different model numbers, 1475 and 1475s (I assume with the small slide) I like the swivel seats beter then the sofa in the slide but, I will try to see both in Conn. next week in person.
    That is why it hard to judge a Casita... you have to go to Tx. which is a haul from NY
    Dave
  • Harleybullet wrote:
    Tibbitts
    Dave
    For me I'm not sure just seeing one would help, unless I could rule out the Casita based on bathroom space or something. I would have to live with the Casita or a similar-height trailer for a while to see how I adapted to the height. I went into a stick trailer with same height as the Casita at an RV show and wow, that was annoying. Would I get used to it after a few days or weeks? Maybe. Without those four inches (really just two inches) being an issue, and assuming the bathroom worked to some extent, I would vastly prefer the Casita.
