rowekmr's avatar
rowekmr
Info on TPMS for 06 Ford Explorer
Hello
Just bought my 4th Explorer a 06 XLT 4.0L 4x4 and the TPMS sensor gave a warning on dash (not the low air light). I took it to Firestone to get 4 new tires (it was on a spare) and they said one of the sensors was bad and quoted me a price of 200 to fix/replace it. I have been looking and see there is a valve sensor and a banded sensor (I think I have the banded one). Which parts besides sensor need replacement and can I use aftermarket like Dorman, etc or should I stick with OEM parts and what is the approx. price of part. I think they are charging too much but want to confirm this and see what my options are. I read elsewhere that they have a battery life of 10 years/150K and when needing service close to those figures its best to replace all as preventative maintenance. Is that an accurate statement?
Thanks
Thanks
  • Home Skillet wrote:
    Look at your valve stem, that will determine what system you have.
    The band mounted sensors use a rubber valve stem.
    Stem mounted sensors have a hex headed nut holding the stem on.
    The sensors run around $50 each. To reset the sensor will require the vehicle to be driven for about 5 miles.
    OEM is always the best.
    Ford now has 3 types of sensors
    http://www.oreillyauto.com/site/c/search/TPMS+-+Sensor/05430/C0337.oap?make=Ford&model=Explorer&year=2006&vi=1432146
  • Depends on if the band and cradle are destroyed, aftermarket is ok. Parts plus mount and balance 1 tire. 99% sure you have a banded one.
  • Look at your valve stem, that will determine what system you have.
