Bedlam
Feb 03, 2018Moderator
The Aisin is geared lower than the Ram transmission allowing for easier starts on grades better slow speed maneuvers. 4.10 gearing should provide plenty of torque to the rear, but I suspect much of your towing will be in fifth gear and dropping down to fourth or third on hard climbs.
My chassis cab is not run empty, so I went with the 4.44 ratio that allows most of my towing in sixth and dropping to fourth on the steepest grades. I needed the payload of this class truck and don't feel this would be a good fit your needs unless you get over sized auxiliary fuel tanks and tool boxes that would push your rear axle weight over 10K lbs.
