Area13
Apr 28, 2016Explorer
jimh425 wrote:
I don't think the ride was much worse with 19.5s on my SRW. It did track grooves a lot more until I started running lower pressure in the front. Just fyi, for my F450, the recommended front tire pressure at GVWR is only 80 lbs.
I specifically wanted a DRW with 19.5s for the extra strength tires. I'd look around for used wheels/tires if you want to save a few dollars.
OK, thanks for the tips.
44,056 PostsLatest Activity: Jan 12, 2020
