Huntindog
Jun 02, 2020Explorer
Carvhors wrote:
I adjusted the bearings...there was slight movement in that wheel, but it’s snug now.
How did you "adjust" the bearings?
There NEEDS to be a slight amount of play when the hub and bearing are cold. You can use a dial caliper to measure it, or follow the specific instruction of the axle manufacturer, which will result in the correct amount of play.
If there is no play when cold, then they will be tight when hot!
Too loose and too tight are both bad.
