ADA6969's avatar
ADA6969
Inside to outside temp difference
Hello,
On my 2002 A/F 990 At any time there was a 10 degree difference between outside temp and inside. Summer it was cooler inside. Winter it was warmer. No heat or a/c on.
On my 2021 1150 A/F If it is 100 out it is 100 inside. IF it 30 out its 30 inside. Windows open/closed makes no difference.
What are you seeing in temp's
Thanks Andy
  • I think it depends on how long is it sitting without heating/cooling and is it in the sun or not. For mine, sometimes it’s hotter than the cold air outside, for instance when it is in the sun. Sometimes cooler on a hot day, sometimes the same if it’s been sitting a long time.
  • I see 10 degrees mostly, sometimes a little more in my Bigfoot. I mostly look at the coldest morning temps.
  • Is your thermometer on an outside wall? If it is move it to an inside wall location.
  • My TT, a 2015, is similar to your 2002 during colder and hotter camping.
