RoyB
Nov 15, 2015Explorer II
Thanks for the POST - Just curious if your HDTV has ever blanked out on you especially when you are picking up OTA HDTV signal with your outside antenna.
Years back the LED units that had built-in DC REGULATOR circuits would do this to you. I like the round unit idea you have found here that just plugs into the wedge socket.
I ordered high dollar boards back in 2009 that had the DC regulator chips on the boards and they all blanked out my HDTV when I had the LED lights on... I gave them away and got the cheap $4.99 boards from EBAY/CHINA that are still working today...
If you would run a test for me and post the results using the LED lights ON and watching HDTV with your OUTSIDE TV antenna...
My sticky tape keeps coming loose on the ones I have in my OFF-ROAD POPUP trailer..
good price for the Super Bright Cool White T10 Wedge 42-SMD 3528 LED Light bulbs but I think i would try to find the WARM WHITE MODELs verses the COOL WHITE... The BLUISH colors would bother me... (This is just me)
I just noticed the AMAZON sells these for some $22 and says PACK of ten. Curious if that is $22 for each unit or for the PACK OF TEN...
I finally read a DC VOLTAGE rating for 11.5 to 12.5 VDC - now I am curious how these would hold up when the converter/chargers goes to 14.4VDC when charging... If the lot of TEN for $22 is good think I will try a pack of them...
Roy Ken
Roy Ken
44,054 PostsLatest Activity: Aug 13, 2015
