- 1kennyOGExplorerwould there still be low voltage when plugged into 30amps?
thankswestend wrote:
I would suggest putting a meter on the battery and a meter on the circuit board to measure voltage. The dim lights are an indicator of low voltage. - 1kennyOGExplorerYep, tried the drive too :)
- bobndotExplorer IIsounds crazy, but take it for a drive , I had to do that in order to free up a line.
http://www.forestriverforums.com/forums/f113/dometic-fridge-not-working-at-all-29566.html - westendExplorerI would suggest putting a meter on the battery and a meter on the circuit board to measure voltage. The dim lights are an indicator of low voltage.
- Mandalay_ParrExplorerTime to call a mobile tech.
- Old-BiscuitExplorer IIICheck out pgs 7 & 8 for a start...........Manual
- 1kennyOGExplorerPropane is on.
furnace works
stove works
everything works except for the fridge. - 1kennyOGExplorerNew/full battery on RV.
does the fridge have a battery I don't know about?
Fridge does not work when RV connected to 30A - donn0128Explorer IIShould have bought a Dinosaur board. Gas on? Gas lines purged? Good 12VDC? 120VAC at the outlet?
- 2oldmanExplorer IIBad battery?
44,029 PostsLatest Activity: Jan 21, 2025
