VegasBT wrote:
I have a Coleman 191QB, and I've been considering adding LED step lights to the folding steps. My concern is where is the easiest point to tie into the existing DC electrical system. Should I run a line up to the battery connection or try to tie in to the existing DC electrical system? I am not sure if the electrical lines run on the bottom of the trailer, and I have been unable to find a wiring diagram online. Any advice would be appreciated!
Is the converter just inside your door....like on my Coleman/Thor???
If so, you could tap into it there.
How do you want to control it??? Do you want to control it with the same switch as the outside light, or do you want it to be independent? There are severa questions that need to be answered in order to possibly streamline your installation.
