AnEv942
Jun 06, 2019Nomad
My 1st thought, as ours is only a few feet from battery, would be replace cable with a longer one. Would also be the least restrictive to its length.
A box with stud where you could immobilize both cables.
ANL fuse or reset-able breaker would make good 'junction' to add cable. Rated higher than what might be at either end.
Last option would be nut & bolting eyes of cables together, I wouldn't, invariably will loosen. If you need to, add extra so you can zip tie the cables together, put in a box.
44,071 PostsLatest Activity: Aug 30, 2026
