ryanPSD's avatar
ryanPSD
Progressive Dynamics converter location
Hi everyone, new to posting here. Hoping to get some input on what I am thinking of.
We have a newer (<1 year) RV and while the converter in my WFCO 8955 "works" it only charges in the float 13.2v state.
From the factory, the converter's 12v side is wired to the DC distribution board: white to the shared negative lug, and red to the dual fused positive lug.
If I replace and wire the new converter in the same fashion, the positive side run is an easy 15 feet to the battery, via another compartment where it is tied into the generator and engine alternator first.
However the power center is physically only 2-3 feet from the battery compartment.
Is there any reason I couldn't just replace the old converter and instead of wiring to the 12v distribution board as before, wire the converter directly to the batteries? This would power the 12v side of the RV through the batteries instead of directly to/through the board.
I currently have the two factory 12v batteries, and will eventually replace with two or maybe four 6v batteries. Given this I'm thinking of the PD9670 for increased output, over the 4655 which seems to be a common replacement.
The 15 feet mentioned above to the batteries is only 6awg, so if I push more amps while charging, it will be a heck of a lot easier and cheaper for a 3-5 foot run of 2 or 4awg than 15 feet.
Thanks guys!
Edit, sorry I had searched on this topic but could not find much. Hope I didn't miss anything obvious.
