RustyMacIntosh's avatar
RustyMacIntosh
Explorer II
Nov 30, 2019
Installing rear wireless camera
I have a generic Fleetwood 19ft Mallard. No window to the rear.
My intents are to install a wireless camera. The instructions are in colloquial Engrish but understandable.
The instructions indicate that the rear camera is triggered ON by the backup light. Reverse. Which I do not have on my Mallard. That is, it is no big deal tapping into the reverse light power cord at the back of the Suburban.
The screen for the front of the Suburban is straight forward. The manufacturer has a cig lighter plugin-with a trigger switch.
So at the rear of the coach. I am thinking of going into the aluminum at the back but not at the very top, maybe down a foot or two, then drill a hole big enough to push the video wire and red wire which is for the reverse light. My unit the furnace is right at the base on the rear of my trailer. I know there is 12v power there since I worked on it swapping in a controller and circuit board earlier this year.
The rear of my trailer is full cabinets. I think coming through the skin at the rear, and taking the power from the furnace....
Does this make sense? Obviously I need a power source. Since I do not have reverse lights on the back of the trailer eliminates that. Plus I want the ability to see who is behind me even if I am not backing up. But I don't want the camera on 24/7.
Reverse light is momentary power. Tapping into the furnace power is 12v 24/7.
Any ideas?
  • First off, what is the brand and model of the camera?
    Most folks who install after-market back up cameras will wire them through the running lights on the RV. Usually, the wires are connected to the red clearance lights at the rear of the camper.
    What this means is, as long as your headlights are on, the camera is on. Its not just on when you engage reverse. This is great when driving because the camera is now an observation camera, not just a back up. So, when you hitch up tow vehicle and trailer, the power is available for the camera. Of of course, when you unplug from the tow vehicle, the camera is off, and not running non-stop. That also means, if you want the camera working as an observation camera, you have to keep your headlights turned on.
    If your camera is a wireless camera, this works very, very nice. If it's a wired camera, then you are still going to have to run a separate wire to the tow vehicle to run the monitor.
    Give more information on what type of camera this is.
    Good luck.
