the_bear_II
Jul 21, 2014Explorer
The receivers will work if you lay it on it's side, you just have to prop it up so air can get into the vents. I don't know if this will give you mor options for placement.
We've never permanently mounted ours so we can take it back and forth to the house. I have run the cable coming from the sat dish through a window or through the slideout gasket.
Most cables can be run inside of cabinets and down the vent pipes running to the storage compartments to get to the other side.
44,056 PostsLatest Activity: Dec 27, 2025
