Golden_HVAC
Jul 07, 2015Explorer
So much stuff to get out and put away before leaving. . .
Sure it is easy to get the power. I installed a couple of cigarette lighter receptacles in handy places in the basement storage. You can buy a 2 cigarette lighter receptacle at Radio Shack (hurry before they close to many branch offices) for about $12. Then wire those to #12 wire coming from the battery or another 12 volt source with a 20 amp fuse someplace.
Then you can run a 12 volt plug from the LED's to the cigarette lighter receptacle. You could use small wire for this, as the LED load should not be more than 1-2 amps.
Good luck!
Fred.
Good luck!
Fred.
44,067 PostsLatest Activity: Jun 05, 2026
