Sort By
- APTExplorerOh, the other connector (4-pin) is if you wanted to connect multiple strips together from the same controller. You will likely cut that off. I cut about two feet off my strip for example.
- ktmrfsExplorer IImine aren't color changing or dimming, so the wire off the strip is a pair of #18 insulated wire. I drilled a 1/8" hole through the trailer wall, and into the compartment above the microwave. That's where the inside switch wiring goes to connect to the outside big round light. disconnected the wires to the outside light, connected to the new led strip lights, sealed the wire coming through the side. done.
- Doug33ExplorerLast week in Delaware, two of my neighbors had these LED lights under their awning, and left them on all night long. Fortunately, their TTs were facing away from me. Otherwise I would have felt like I was in the midway of a local County Fair. They were obnoxiously bright.
- APTExplorer
2012Coleman wrote:
So you are saying to cut the wire where indicated here?
Yes, somewhere between the "brick" (120V AC to 12V DC adapter) and the white controller. Long enough for some slack, but the more wire the more that has to be cleanly stored/hidden. There are sets available from Amazon without the AC-DC adapter - controller and strip only, but you need that round conenctor and $8 is just as reasonable as Radio Shack. Use a meter before you cut that wire in order to determine which is 12V and which is ground.
Will the remote sensor also work if you put it inside the porch light fixture? also, what is the plug that is coming from the center of the spool for?
I drilled a hole in the top of my porch light housing to run the 4-lead wire and antenna out. Once all hooked up and functioning, I sealed the hole up. So yes, the remote works on mine. The antenna wire is tied up in your picture....the porch light would be on whenever the LEDs were on - which would not be so good.
Right. I can't imagine you'd still need the porch light, except as a backup in case something were to happen with the LED strip.
You seem to have a good understanding. If you have ever worked with automotive stereos or lighting, I doubt you'll have a problem with this project. My TT is currently @ storage, or I'd snap a few pictures. - 2012ColemanExplorer II
APT wrote:
I also have a porch light near one end of my awning. So I spliced that wire and hide the controller in there. This kit would work well. You don't need the AC adapter, but you do need the female plug from it. I just cut that end off and connected to my 12V porch light.
The remote has on/off buttons so it seems this would work for me as I could turn the LEDs off while having the porch light on, but this would also mean the porch light would be on whenever the LEDs were on - which would not be so good. - APTExplorerYou wont' need the porch light if you get an RGB 300+ LED strip. You can have white, orange, blur, purple, yellow, pink, etc, all plenty bright or not so much. If you do want the porch light also, then you'll want a separate switch for them instead and using the existing wiring doesn't make as much sense.
- Majja13ExplorerEven if you pulled the complete light socket off to get to the wires it ould only take 2 wire nuts to splice it into the light and that way you do not loose the use of the porch light.
- shar3890ExplorerOur refigerator is on the awning side of our trailer. We put all the wires, and the controller inside the compartment and just plugged into the outlet. We let the electric eye exposed through one of the vents. Crazy simple !! No drilling or re-wiring.
44,030 PostsLatest Activity: Apr 30, 2025
