- 2012ColemanExplorer II
joelyn wrote:
Thanks - was hoping this gizmo let you keep the porch light bulb. Maybe splicing is the way to go if you still want the porch light.toaobigal wrote:
A 1141 bulb is the same socket as a 1156, they're interchangeable.
thanks. so this should fit if anyone looking for one.........
1156/1141
correct me if i am wrong
thanks
Please don't rant about porch lights. We only leave it on if necessary - we plan on returning after dark and the area is not sufficiently lit. - myrvhasnotvExplorerThanks
- toaobigalExplorerA 1141 bulb is the same socket as a 1156, they're interchangeable.
- APTExplorerAs far as brightness goes, I have seen several of the OEM white strips. They are just on/off. Mine has 3 color RGB, which let me pick several shades of the rainbow, and dimming controlled via remote.
For the white only OEM setups, you can get a potentiometer or PWM dimmer for under $10,, like this one. - myrvhasnotvExplorerI have the led under the awning and I have to say it's too bright. Maybe when it ages and yellows a little it will be nicer. I think just under the skirting might be a better place. It would look like a street rod but the indirect light would be nice and the bugs would be away from the door. We used our old rope lights last trip per the wife's request.
- joelynExplorer
toaobigal wrote:
The light bulb in the porch light is a 1156, I ordered some 1156 socket adaptors from ebay. It's basically a socket with 2 wires sticking out of it. My LED module is small enough to fit inside the porch light, all you have to do is grind a little groove on the lens so the wire can come out. I can't get the link with my Ipad, but on youtube, the video for LED strip for rv is from FPV DEE.
my porch bulb is a 1141 and i have checked ebay as well as amozon but only found this one which is a different size............
adaptor
anyone have a site for this adapter but for a 1141 bulb? seems like the best way to go with the install - toaobigalExplorerThe light bulb in the porch light is a 1156, I ordered some 1156 socket adaptors from ebay. It's basically a socket with 2 wires sticking out of it. My LED module is small enough to fit inside the porch light, all you have to do is grind a little groove on the lens so the wire can come out. I can't get the link with my Ipad, but on youtube, the video for LED strip for rv is from FPV DEE.
- pyro383Explorerhere is how I did mine
http://forums.woodalls.com/index.cfm/fuseaction/thread/tid/27723120/gotomsg/27744842.cfm#27744842 - joelynExplorer
2012Coleman wrote:
toaobigal wrote:
A socket adaptor sounds easier than splicing wires. Can you link to the one you used or tell me where you got it? How about a link to the Youtube procedure?
I have a porch light near the door, I used a socket adaptor and I power the led strip from there. It has a switch inside the trailer. I found the procedure on Youtube.
Agree that this would be better than hanging lights which have to be taken down often in a hurry when a storm is blowing in.
sounds like a good idea, maybe that utube link and maybe the socket adapter.
thanks
44,052 PostsLatest Activity: Nov 23, 2025
