- narcodogExplorer III used 3/8 foam board that has the foil on one side. Then I added an Electowarmth mattress pad, works well for me.
- SidecarFlipExplorer IIII used a sheet of the pink 1" underlayment foam board from the lumber yard. It was less than 15 bucks. Cut to size with a serrated knife.
- lap527Explorer1" foam egg crate under mattress worked for us.
- Old_DaysExplorer IIWhat we did was put a 1 inch foam pad on top of the mattress, that made a big difference. You can buy them at Walmart.
- romoreExplorer IIHeadroom is already at a premium so adding under the mattress may not work well. I had rebuild the nose on our fiver and used foamboard under the floor instead of the original pink insulation.
- CloudDriverExplorerA 1-1/2" thick memory foam topper on our cab over mattress solved the cold mattress issue for me. Made a big difference.
- Camper8251ExplorerI put 1" foam board under the mattress on mine. Seemed to help quite a bit also added a 12v heating blanket on it as well.
Used to do a lot of ski / camping up at Manning Park in BC till they raised the prices thru the roof.........
44,070 PostsLatest Activity: Aug 05, 2026
