randy1953's avatar
randy1953
interest question
What do any of you guys use to protect your travel trailer cover from the sharp edges and overhang of the corner gutter drain extensions?
  • rbpru wrote:
    I use the split foam tube design for hot water pipes, folded over and duct taped in place.
    plumbers call this "donkey d!#k" (at least the ones i know do). seems a perfect solution for protecting corners.
  • I use the split foam tube design for hot water pipes, folded over and duct taped in place.
  • Foam pipe wrap held in place with clear duct tape, Reflectix wrapped around the lower edges of the trailer body and each end of the awing, also held in place with clear duct tape. Been doing this for years, works like a charm with little expense. :B
