rjstractor's avatar
Apr 18, 2019
Interesting new application for 6.7 Powerstroke
I didn't see this coming!
Pierce pumper with Powerstroke Diesel
I don't see this powertrain revolutionizing the fire service world, but it might turn out to be a good option for a smaller department in a flat area. It's down on horsepower and way down on torque compared to Pierce's top of the line apparatus, but with the right gearing it should perform ok on the flat. Pierce is one of the top manufacturers of fire apparatus in the world, so apparently they have a lot of confidence in this powertrain.
  • This seems awful heavy for a truck that can be used on the roads:
    Front GAWR (maximum)
    18,000 lb
    Rear GAWR (maximum)
    27,000 lb
  • theoldwizard1 wrote:
    WOW ! About 10 years ago, I knew a guy who was trying to convince Ford to try to get in the mini/portable pumper business ! Not build the vehicles/pumps, just provide engineering assistance in how to connect up the piece and modify the electronics. No one within the company was interested !
    An F550 dually could carry a lot of water to a remote fire !
    And the anticipated F600 will carry 15% more.
  • WOW ! About 10 years ago, I knew a guy who was trying to convince Ford to try to get in the mini/portable pumper business ! Not build the vehicles/pumps, just provide engineering assistance in how to connect up the piece and modify the electronics. No one within the company was interested !
  • This is listed under the tranny. Available live-drive power. What is it? Never heard the term before.
    Thanks
  • Well that would work out good for our fleet. Most parts that we stock for the rescues for the 6.7 would also be used for this application. Most of our fire engines run Cummins engines which are also very reliable. Regardless I can see several Dept fleets considering this application.
  • "IF" geared correctly for the tire diam, torque and the rather tall 3.1-1 first gear of the torqueshift, one should still have 30-35% gradability at 35K-40K lbs that this rig could run down the road at. Not sure I would want it on the freeway at 60 mph, might be running some high screaming RPM! 850-1000 lb ft would be better, with a low gear in trans at 3.5 to 4-1 to go with some 5.13 to 6.x-1 gears with those taller tires would be better option in my book!
    Marty
  • ShinerBock wrote:
    V configuration engines are perfect for cab over trucks where space is an issue. That is the sole reason why Cummins made the ISV 5.0.
    That's a good point. Our Pierces with Series 60 and DD13 engines have huge doghouses that take up a lot of cab space. I think that little Powerstroke would have a tough time on the hills where I work. That Saber chassis is a lot lighter than the Enforcers and Arrow XTs that we operate though.
  • V configuration engines are perfect for cab over trucks where space is an issue. That is the sole reason why Cummins made the ISV 5.0.
  • Good for Ford, but I'm having trouble figuring out why this configuration would be offered when there are so many others already out there. Reading the material on Pierce's site sounded an awful lot like Ford advertising material! :B
