terryrey
Jan 10, 2017Explorer
INTERSTATE 2500HC 6 VOLT BATTERY EXPERIENCE
I currently have installed in my Outfitter Apex 8 two Interstate 6 volt golf cart batteries. They are 6 years old and have given wonderful service, but at some point will have to be replaced. After doing some research online, I have decided that good replacement batteries would be two Interstate 2500HC 6 volt industrial deep cycle batteries. Interstate 6 volt golf cart batteries are also classified as an industrial deep cycle battery, so the same longevity and durability features of the golf cart battery are shared by the 2500HC battery - this was confirmed by Interstate Customer Service.
Interstate GC2-XHD Golf Cart batteries are rated at 232 AH (20 Hr rate), weigh 66 lbs, and are 10.25" long X 7.125 wide X 11.125 high. By comparison Interstate 2500HC batteries are rated at 283 AH (20 Hr rate), weight 77 lbs, and are 11.625 long X 7.125 wide X 11.625 high. So for an increase in weight of 11 lbs per battery (22 lbs for two 6v batteries in series) and a slightly larger footprint (which will fit my battery box) the 2500HC's give an extra 51 AH capacity, a 22% increase over the golf cart battery.
So the purpose of my post is to ask if anyone has used Interstate 2500HC 6 volt batteries and, if so, what was / is your experience - good, bad...?
Thanks for your input...Terry
