Vinsil wrote:
Had a 95 F350, 4x4, powerstroke, 5 speed, 3.55's and ran 35" tires.
Found that the powerstroke was most happy at 1800-1850 rpm fuel mileage wise. Once it started to turn over 2k, whether due to speed or downshift for hills, it sucked down the fuel.
X2. My last 7.3 had 4.10s and even with 285s I felt it was geared too high. Anything over 2k sucks the fuel.
My current 7.3 is a 2001 SC LB with a 7.3 and 6 speed with 3.73s. Also around a 3 inch lift. WIth 35s it did great with a camper and trailer, loaded to 18.8k lbs. I recently put on 33s (305s) because there were no 35s with a high enough load rating, and lowered the front end an inch to compensate for the camper. It also rubs the inner well less with the 305s.
Make sure you keep a little rake in the truck, and also make sure you get tires with a rating of 3700 or more.
Keep the 3.73s, especially if you are getting a chip.
Here's with the 35s
And 33s with a little lower front.
