otrfun
Feb 02, 2023Explorer II
LaneW wrote:Every installation has its own unique set of variables, so there's no way to guarantee any given result. Ultimately, the right choice boils down to a person's aversion to risk.
Really? I'm trying to verify this. How did you get the info? I am just about to pull the trigger on an inverter and want to make sure it will power my 900 w microwave that shows a draw of 1350 watts, as stated earlier. I have been wavering between Renogy, GoPower and Victron. Victron is a lot more expensive, but I want to do this right. GoPower is about $700 US and Renogy a lot cheaper. I don't want to cheap out, but don't want to spend the extra if the Renogy 2000 w in the $300 range will really work well. How do I confirm this?
Thanks!
Me, I'd give the Renogy RNG-INVT-2000-12V-P2 a try. Amazon sells it for $306 with a 30-day return. Even if it only has a 4000 watt *peak* surge/power rating (vs. 4000 watt for 5 sec), it still may work. For me, it would be worth the risk of a simple return to potentially save $400-$800.
