StirCrazy
Feb 02, 2023Moderator
LaneW wrote:otrfun wrote:StirCrazy wrote:Thanks for clarifying, Steve. I have no reason to doubt you were quoted 4000 watts for 5 sec. I've had all kinds of specs and claims quoted to me over the years.
no, it is thier one that is on sale for 369 cdn right now and includes battery cables and a remot control
2000W 12V Pure Sine Wave Inverter
SKU: RNG-INVT-2000-12V-P2-CA
Steve
Interesting that Renogy fails to advertise this outstanding capability anywhere in writing. All their online literature and specs simply claim a generic 4000 watt *peak* surge/power rating.
For the sake of discussion, I will say this: *IF* this $300 (US) 2000 watt Renogy RNG-INVT-2000-12V-P2-US inverter is capable of 4000w for 5 sec, it would make it one of the best performing high-frequency 2000w inverters on the market, regardless of price.
Unfortunately, this is a huge if. As they say, if it sounds too good to be true, it probably is.
Really? I'm trying to verify this. How did you get the info? I am just about to pull the trigger on an inverter and want to make sure it will power my 900 w microwave that shows a draw of 1350 watts, as stated earlier. I have been wavering between Renogy, GoPower and Victron. Victron is a lot more expensive, but I want to do this right. GoPower is about $700 US and Renogy a lot cheaper. I don't want to cheap out, but don't want to spend the extra if the Renogy 2000 w in the $300 range will really work well. How do I confirm this?
Thanks!
it will run your microwave no problem. I put in a inqury ticket on there web paged and had to go back and forth with a couple emails to get the information I was looking for. so for the overload they said a few tenths of a milisecond but the max power should hold up to 5 seconds. there are plenty of reviews of people using it for tools and such which would be a harder starting current in my opinion, also several who use it for there microwaves. if you think about it your household 15amp breaker which most people run a mixrowave off of has a limit of 1800 watts but a much larger capacity to run over.. a 900 watt microwave could pull up to about 2700 watts at start up but that kind of in rush or what ever you want to call it only lasts a few milli seconds. on a electric motor it can last significantly longer.
I personaly wouldnt have an issue running my rv microwave off this one or even a larger countertop. but if your on the fence about it you could buy the renogy 3000 watt inverter on sale right now for 469.00 both the 2000 and the 3000 have plugs on board and the ability to wire it to the fuse panel so it can power any outlet in your rv. they also have the remote control pendent so you can set the main unit in auto and turn it off and on as you need it from inside the rv. I have my 2000 watt go power mounted in the front storage comparment by the batteries and then wired directly to my breaker panel so when I want to use the coffee pot or the microwave I use the remote panel to turn it on then switch it off when I am done so I am not drawing standby current.
Steve
