westend
Jun 29, 2018Explorer
Traveler21 wrote:2 amps left overnight will not fully charge any battery used on an RV. The best you could expect in the Summer would be 20 amp hours put back into the battery. If using a portable charger, aim for anything over 10 amps but running a generator, it will be costly. A 40 amp charger would be better.pianotuna wrote:
How were you deciding the battery was fully charged?
The 12V charger on 2 amps for overnight left battery at 13.1 V
The battery (swapped over ) will crank my big truck no problem.
Battery was new July 2017 and was kept charged although on my 3-4 day trip it discharged each day, so we ran the portable generator all day to recharge that battery ( disconnected ) to bring battery back. Soon as hooked up to terminals heavy discharge. Again this battery maintained since July 2017
Kept on a floating charger , So my guess is battery good -
You have multiple problems that I can see. Perhaps a large draw on the battery but also, an inefficient charging regimen.
If you are only adding in 20 amp hours/day, you will constantly have a severely discharged battery and that will lead to a loss of capacity, quickly. A typical lead acid battery should only be drawn down to half of it's capacity. A marine hybrid battery will withstand a dozen of these cycles with a small capacity loss. A conventional lead acid car battery won't withstand a dozen and will be worthless. A good deep cycle battery may withstand more than a dozen full discharges but will still lose capacity.
READ HERE: 12 volt side of life
44,056 PostsLatest Activity: Jan 12, 2020
