Traveler21's avatar
Traveler21
Inverter failure on my 22' Trail Cruiser
Hello Forum
I am new here, and would like to like to introduce myself and fish around for some help.
My trailer is a 08 R-Vision Trail Cruiser 22' pull trailer.
Id had the trailer stored its life here in level driveway, much of the time on shore power.
My battery died so I replace with good battery
Battery last 3 days , drains itself dead. And kills the rig ahead of the plug where the trailer attaches if left attached ( tow vehicle's battery)
I learned the Inverter system needs a good battery just to test.DC or AC
To make instrument panel in bathroom light up, or even to get 110V shore power. to the inverter...I need a battery in place
this is a single battery trailer.
So with the battery in constant discharge , Is possibly a bad inverter?
Or a direct short to ground , to drain a battery in a few days with breakers OFF..
I do not know where to start. I was going to just buy an inverter but that will not help if there is a conductor ( thru the frame) that might be pinched .
Trailer would be nice to have working now , great weather.!
  • Yes I did mean converter, not aware of the correct term
    . I have it "out " but still attached to wiring
    Unplugged from shore power at moment. Been keeping battery topped -off ,disconnected terminals from trailer while I try to sort this out.
    Would a faulty converter cause a rapid discharge of DC power when not on shore power?
  • Do you mean "Converter"? That is what normally keeps the battery charged and provides 12V for on-board items. It sounds like yours isn't working. A modern converter doesn't need a battery hooked up but you do need one to make all the 12V stuff work when not plugged into house current. You DO need a battery for the trailers emergency brakes.
    Inverter takes 12VDC and makes 120VAC.
